Page 2 of 3 1 2 3
G
G Offline
Just a few minutes ago I contacted Cessna Plane Parts for a quote on the Clock for my "150". The price was $418.20!! laugh laugh
It was involuntary, but all I could do was laugh!!
Yep! I was in my 20's and unwittingly built myself a small bomb! There was no more than 2 or 3 drops of kerosene in that clock. I must have figured it wasn't enough to raise the mix to a combustible level.
WRONG! eek
BTW, the clock ran for a couple of weeks after that, but once the kerosene completely evaporated, it quit again.
Really Carl... Really
What on earth were you thinking!!!!!! laugh laugh laugh , as I was reading that, I could see the outcome before I even got close to the punch line laugh Ya killing me here...... laugh laugh laugh laugh
That's one of those Darwin things isn't it!!!! whistle whistle whistle
[/quote]
Well, he already admitted to cleaning an engine block in the bathtub. Why does this surprise you? ...or it doesn't! laugh
A man's gotta do what a man's gotta do! smile
I'm (much) older and (a little) wiser now! whistle
I have heard of some clocks being replaced with ones from Sporty's for a LOT less!
G
G Offline
Ronald,
The Sporty's digital is just above my clock!! Why anyone would want to go back to the original style is beyond me. Having said that I applaud those who try to keep everything just like it left the factory. They are real time machines. For me, function wins out over style points,on the otherhand, I have a military eight day that came out of an F-86 that just might fit where the electric clock is now. We shall see!! grin
Originally Posted by Wayne_Westerman
I can't say for sure that all electric clocks work the same way but a couple of years ago I tore into a non functioning clock and was a little surprised to find that the clock is really a mechanical clock with the main spring replaced with a solenoid. About every 20 seconds the solenoid activates and winds a little "main Spring". The clock will tick tock for about a minute if the solenoid is not tickled.
I've got one of those in my '68 Buick. Every minute or so I can hear a 'click!' as the clock winds itself.
What's also surprising to me is that the act of setting the time on these mechanical ones also adjusts the speed of the clock. If the clock is running fast then turning the hands back will cause the clock to run a few seconds slower per hour. After setting the clock a couple of times, my Buick is pretty accurate - a month later and the time is still correct, not bad for a mechanical clock.
Nowadays one can get the mechanical innards replaced with a quartz clock. Externally it looks the same, but internally it uses a quartz-crystal controlled electric motor. The result is incredible precision, no need for speed adjustment and no winding (so long as the electricity keeps flowing).
Here's one from Spruce [aircraftspruce.com]. Same clock, just over a hundered bucks.
Mark #271340 07/17/10 08:03 PM
The Sporty's clock has that annoying "Not for certified aircraft, for EXPERIMENTAL aircraft only" disclaimer. The "FAA/PMA-approved" clocks are nearly $300. What a rip.
Visit the CalDART website:
www.caldart.org [caldart.org]
David,
Send MORE money!!! I didn't charge you enough. grin
Page 2 of 3 1 2 3
