Bengie Phillips #375342 10/11/12 12:16 AM
If you look at all the pictures, there is a replacement tailcone ready to install included with all the "parts".
I would suspect that the recovery (flipping the plane upright) was botched and damaged the tailcone like that.
Regardless, why would you want a 180HP engine on a 150?
A friend at work flew gliders near Avenal, Ca., and there was an Aerobat with a 180hp engine as a tow plane. He said there were serious overheating problems with the plane...
This plane NEEDS long range tanks. Maybe it was a tow plane/banner tow, but you can't tell with the tailcone ripped up.
Still, cool project if the price is cheap.
Brian Anderson #375377 10/11/12 03:39 AM
Harry Delicker at Del-Air says it's his most popular STC for the 150. When we were putting together my 150/150 STC kit, he told me that there wasn't much call for the 150HP STC. Most were going with the 180HP STC. Most of the STC parts are the same, with probably the engine, propellor and baffling being different. I wouldn't be surprised if the cost of an O-360 wasn't significantly higher than an O-320. Especially when figuring out how much the whole conversion is going to cost, going for the extra HP probably makes sense... at least on paper.
I decided against the 180HP version because of the higher fuel burn of the O-360 engine and the decent data on the 150HP conversion that lead me to believe that 150HP would be more than sufficient for my desires.
150HP turned out to be everything I wanted it to be, and then some. And the fuel burn isn't as much of a concern with what I've learned about operating my 150/150.
Well, there is that... smile I have to watch the oil temps pretty closely on mine in the summer. I think it has a lot to do with the high DAs I see here in CO that time of year. I've noticed that at lower elevations, such as when I go to Clinton, the oil temp is much less of an issue even when the OATs are similar to what I fly in at home. During the rest of the year, the oil temp is not an issue. There seems to be a direct correlation between the amount of throttle and the oil temp. Pulling the power back is the best thing I've found for keeping the oil temp away from the red line. I can imagine that an engine that produces more power would produce more heat and thus, higher oil temps.
It's probably just as well I went with 150HP. I certainly have no regrets.
David Rowland 7CO0
David Rowland #375484 10/11/12 11:03 PM
I tow gliders with a 180HP 150L Aerobat with a STOL kit. I'm full power from brake release to glider release then back to the pattern at 120 mph (1800 rpm on the descent and 2300 level). We haven't had any overheat problems and it gets pretty hot in the summer in San Antonio.
While 180hp is okay for glider towing, if I had a bigger engine in my personal 150 it would be an O-320. I've always thought that the 150/150 with long range tanks would be a great personal plane. 180 hp is overkill unless maybe you had a float plane.
Tim
'76 C-150M, San Antonio
David Rowland #375486 10/11/12 11:14 PM
Oil temp has never been a problem with our 150/150 either? In fact as temps start to cool down now it's hard to even get the temp up into the green. I believe that there are a couple of different oil cooler installations approved? Maybe this makes the difference?
