#421097 11/22/13 12:18 AM
F
F Offline
Hi i need,
Front landing gear
Main landing gear (round version not flat)
LH And RH fuel thank
LH And RH Ailerons
LH And RH Flaps
Thanks
Fabio
Welcome! We need to know what plane you have to put these on.
'75 C150M/150 . N45350
F
F Offline
Hi Konrad_Kelley
is a good idea but a not have idea of my version of Cessna 150
I found in a barn and i i make restoration. There is only plate
near engine mount with only serian number.
have landing gear Round section, and i presume is REIMS factory
Hey, a new guy! Fabio, welcome to the club!
Do you have any pictures of the project to share?
There should be a serial number on it somewhere, Fabio, that is the best reference. If it is a Reims, it will be look like F150xxxxx or FA150xxxx. Here in the U.S. we have a data plate near the tail with the s/n on it.
And under the carpet below the pilot seat.
Oh.....and welcome to the club, Fabio.
F
F Offline
Hi,
is a Cessna 150L 1972
in complete rebuild
Hi, Fabio. I've got L&R ailerons, L&R fuel tanks, L&R elevators/horizontal stabs ( with trim tab) and a nose gear fork from a C 150G.
Ailerons: $200 each. Fuel tanks (13gal.) $75 each. Elevators $100 each. Nose gear fork $50.
If you're interested in any of the above, I can get a packing/ shipping estimate for you.
Doug Anderson
N8458J, Amazon Temptress
F
F Offline
HI, yes i'm interest it!
Sure the Fuel tanks and Nose Gear!
i send you one MP
Here's some photos of the tanks, fork, and flap. The flap has some slight bending on the edge, but it looks like it should be an easy repair. The dark streak on the fork is a reflection. The metal is bright and clean with no scratches or pits.
Doug Anderson
