L
L Offline
Where can I find one? Or can it be repaired? It stays at zero and then jumps to about 60
1968 C150 N7016S
New Market, VA (8W2)
Isn't that what our 150's do????….. go from 0-60 just that fast???? LOL!
C-150F
N7123F
Southwest Baby Cessna Roundup… May 1-3, 2015
www.swbabycessnaroundup.com [swbabycessnaroundup.com]
Lee, the air speed indicator can most likely be over hauled. I used Air Parts of Lock Haven, PA Air Parts of Lock Haven [http] to overhaul and re-mark several of my instruments a few years ago. I know others have used other shops as well.
I would also have your pitot system checked to make sure there are no blockages or leaks.
David Rowland 7CO0
L
L Offline
Hey thanks for the info. I hadn't thought about the pitot/static system either.
Lee
1968 C150 N7016S
L
L Offline
0 - 60 furlongs per fortnight
1968 C150 N7016S
When I bought my plane I found the airspeed indicator read high by quite a bit (this about bit me the first time I took off, the plane definitely was not ready to fly at the indicated speed the book calls out). I bought a new TSO'd airspeed, but I bought one that tops out at 160 mph. I think a 180 or 200 mph airspeed in a 150 is ridiculous - it forces the speeds at which we fly almost all the time into a very narrow area at the beginning of the dial. Spreading the graduations out makes it much easier to read and to read more accurately. This is like the 160 mph speedometers on many new cars, which is a pet peeve. The only "issue" is my custom range-marked airspeed now shows redline at 160 when it is supposed to be 164. I figure if I am going that fast, I am already dead, or soon will be.
1967 C182K
I dunno about that, I have caught my self several times while out playing, (coming over a range of mountains into a valley, typically), where I have dropped the nose to loose altitude only to glance at the airspeed indicator and.......... shocked
