Page 2 of 4 1 2 3 4
Here's what a new one from Ce$$na looks like
So where on this is the gold plating? smile Hard to imagine the cost being justified for some if not all parts from Cessna.
We're going to move on without this expensive bit of baffling and see what happens.
Former Owner Of 1971 Cessna 150L
N1471Q ... 71 Quebec Eh?! (It's a Canadian thing smile )
Ocala, Florida KOCF
Glen,
I am getting ready to start a run of panels (for a fairly long wait list)...however, if you send that bracket to me, I will lay it out in a CAD file and make you an aluminum one for free...
You will have to paint it and attach the baffle material so it's an "owner manufactured part" ;-)
Originally Posted by Glen_Coombe
Best shown via the photo. I suppose we could fabricate one but it seems a lot of work. [Linked Image]
Referred to as "bracket assembly - cowl snubber" with the assorted baffles.
Ideas welcomed.
Originally Posted by Bill_Rourke
Glen,
Ideas welcomed.
Cool,
Bill meet Bengie... Bengie meet Bill...
Bengie, how about sending that very nice clean and complete unit to Bill for reproduction!? That way we get the complete picture vs the mess of mine. Also once complete we will have this for other members who may need access to the file.
Is this a great club or what?!? smile
Ocala, Florida KOCF
Kewl, I will probably see Bengie soon; I'll get it from him!
Bill,
You got one in your hangar that only has one crack I believe. We could tape it or glue it up and make a template from it easily I think.
Originally Posted by Jim_C
Mine has been missing since i bought it(8 years ago). At least 60% of the 150's I look at dont have one. I doubt it makes a hill of beans difference to the airflow underneath the engine. My I/A is ok without it being there.
It is my opinion - based on no real scientific evidence - that omitting this baffle is a major contribution to the O-200's reputation for carb ice.
Leaving out that baffling allows pressurized (from outside) ambient air to flow around the filter and then carburetor - lowering the temperature of the body.
Fitting this baffling seals the carburetor in the nose bowl in the warmer air from the engine operation keeping the carb warmer - reducing the chances of carb ice.
I also wonder about what it does to the designed air differential pressure between the cowl intake and the exit around the nose gear which an important part of the air cooling.
YMMV
and you lose about 5 1/2 knots
I have not had carb ice in my 150 other than "possibly" 2 times in almost 8 years of ownership wink Both those times conditions were OPTIMUM for carb ice formation. I dont think that the airflow around the cylinders is affected at all. That air overpowers the small surface area of the filter opening sans baffling easily I would think. Might be some stuff going on turbulence wise at the gear opening, but I doubt it has other than a very minor effect on the flow.
Offset by the RAM air into the airfilter caused by the baffles grin
Page 2 of 4 1 2 3 4
