| | Joined: Feb 2004 Posts: 4,093 Likes: 227 Member/2500+posts | | Member/2500+posts Joined: Feb 2004 Posts: 4,093 Likes: 227 | My bleeder valve needs to be replaced. Seems previous owner opened this little valve with a pair of pliers. So does anyone know the part that I should purchase for my M model 150 76? Any help would be appreciated.
Bruce
| | | | | Joined: Jan 2009 Posts: 2,394 Likes: 2 Member/1500+posts | | Member/1500+posts Joined: Jan 2009 Posts: 2,394 Likes: 2 | Depends which brakes you have. I've got Clevelands and just purchased this [ aircraftspruce.com].
Matt Wash N813JJ Mooney M20K/Encore/TKS 50R | | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | Had to fix the subject line. Bruce totally trolled me with the signature on his post.
| | | | | Joined: Feb 2004 Posts: 4,093 Likes: 227 Member/2500+posts | | Member/2500+posts Joined: Feb 2004 Posts: 4,093 Likes: 227 | Matt, just what I needed. thanks and Kendel, I need to add airplane mechanic to my sig.(kidding) I am one only because I have to do a few things on c150.
BY THE WAY, I think the easiest way to add fluid to these Cessnas is through the bleeder valve. Use an oil can and put break fluid in it, a plastic tube and squirt the break fluid from the wheel while someone unpress the break peddle inside the plane at the same time.
Bruce
| | | | | Joined: Jan 2009 Posts: 2,394 Likes: 2 Member/1500+posts | | Member/1500+posts Joined: Jan 2009 Posts: 2,394 Likes: 2 | Glad to help, Bruce. I just did mine and you may not need to do it from the bleeder. I chose to do it from the pedal given I knew I wouldn't have a bubble upstream.
I landed in the middle of nowhere (Terlingua, TX) 3 hours from home full of people and baggage. While turning to park pedal went the floor. Someone had assembled my piston upside down and the o-ring squeezed out and dripped fluid everywhere. Fortunately I'd just done my annual and was 'full' of fluid.
I flew back home and found a chewed up bleeder valve. Bought what I sent you above, pulled the old and quickly swapped the new, topped up my fluid and bled from the pedal a couple of presses and haven't had any issues since.
| | | | | Joined: Dec 2003 Posts: 15,063 Likes: 763 Member/15,000 posts | | Member/15,000 posts Joined: Dec 2003 Posts: 15,063 Likes: 763 |
| | | | | Joined: Oct 2007 Posts: 2,600 Member/2500+posts | | Member/2500+posts Joined: Oct 2007 Posts: 2,600 | You may want to add these to your list: A pedal is a lever controlled with the foot, such as found on a piano or a bicycle. To pedal is to use such a lever to control something. It descends from the Late Latin pedale, for a thing of the foot, which descends ultimately from the Latin pēs, for foot. To peddle can mean to travel around selling items (think door-to-door salesmen). It can also mean to sell illicit drugs or, informally, to give out or spread, as with information or lies. | | | | | Joined: Dec 2003 Posts: 15,063 Likes: 763 Member/15,000 posts | | Member/15,000 posts Joined: Dec 2003 Posts: 15,063 Likes: 763 | Pedal/peddle are already in my list.
| | | | | Joined: Feb 2004 Posts: 4,093 Likes: 227 Member/2500+posts | | Member/2500+posts Joined: Feb 2004 Posts: 4,093 Likes: 227 | Thanks Barney, Kendel for the sp. help. Should have proof read the post. Spelling is not a strong suit-my apologies.
I did order the bleeder valve kit and hope to install on c 150 soon. Should never use pliers on this small valve nut.
Bruce
