#569364 09/19/18 07:51 PM
I have a collection of leftover bits and pieces from my O-200 build. Check out the pictures if you're needing something. Some stuff is good, some is useless - I just put it all out so I can see what I have. Some parts are new, some aren't. Some for sale, a lot for free... The gears will be mag-particle checked for cracks. Carb has only about 300 hours on it.
Major parts include: Garwin wet vac pump, Bendix mags, M-S Carb, pull-starter, generator, 2 airboxes (no baffle), complete intake set, 2 sets standard pushrods,
New parts:
Intake hose set, rubber pushrod seals, 4x complete cylinder gasket sets, rocker shafts, carb heat repair kit FG100, 8 Champion plugs - four OK, four not so great )they are unused, but no papers)
And whatever else you see there.
Poke HERE for photo album [photos.app.goo.gl]
I could use the hose set, pushrod seals, gaskets, and rocker shafts. I bought all these parts for an engine rebuild but then ended up using them on repairs for other airplanes. Do you have a price for those?
You got it Kendel... I'll PM you.
Assuming you want the new hose set, in the bag.
The un-bagged set has been on an engine, but couldn't have been for long - they're in great shape and very pliable still.
PM Sent
