| | Joined: Mar 2004 Posts: 16,296 Likes: 1220 Member/15,000 posts | | Member/15,000 posts Joined: Mar 2004 Posts: 16,296 Likes: 1220 | If you're worried about the noise bothering others just get a spot near Poobs. First time I heard that I thought the Eighth Air Force landed and was taxiing back and forth inside the old FBO building. and that was during the day.
Ron Stewart N5282B KSFZ | | | | | Joined: Jun 2004 Posts: 36,117 Likes: 778 DA POOBS Member with 30,000+ posts!! | | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 36,117 Likes: 778 | If you're worried about the noise bothering others just get a spot near Poobs. First time I heard that I thought the Eighth Air Force landed and was taxiing back and forth inside the old FBO building. and that was during the day. Sure it wasn't the thunderstorms followin' ya? ...ducking...  ![[Linked Image from animatedimages.org]](https://www.animatedimages.org/data/media/218/animated-penguin-image-0137.gif) [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | | | | Joined: Feb 2018 Posts: 2,226 Likes: 558 Member/1500+posts | | Member/1500+posts Joined: Feb 2018 Posts: 2,226 Likes: 558 | I looked into this a couple years ago. A good Resmed CPAP battery runs around $300. That’ll give you 8 hours of power. I decided to stay in an nice dry air conditioned hotel room. I know, I’m missing all the fun
Alan Blevins 1974 Cessna 150M N150V KFDW Hangar 9C | | | | | Joined: Feb 2004 Posts: 68 Likes: 12 Member | | Member Joined: Feb 2004 Posts: 68 Likes: 12 | Another great example of how great this club is, Ron 20 gave me a great deal on his like new battery pack! I think he just wanted the rest of you to be able to sleep in peace????
Jim Sainsbury 87Y N3862L
| | 3 members like this:
Mark, Ron Stewart, Ron Twente | | | | | Joined: May 2009 Posts: 4,643 Likes: 460 Member/2500+posts | | Member/2500+posts Joined: May 2009 Posts: 4,643 Likes: 460 | I've been using a CPAP in a tent for years, powered with a battery. My main CPAP is a now-older Philips Respironics RemStar with a humidifier. The humidifier is the main load on the battery. Current consumption varies a lot depending mostly on the humidifier setting, from about 3 Ah/night with no humidification to as high as 15 or 16 Ah with maximum humidification from a 12 volt nominal battery. I initially used a conventional Li-ion battery sold for the purpose. It was three cells so a bit under 12 volts but ran the CPAP ok. Then I got concerned about the (remote) possibility of a flaming battery failure in flight and switched to using LiFePO4 type batteries. They weigh just a little bit more but are considerably safer. They're also considerably more expensive, though. A 20 Ah battery was large enough to reliably operate for one night under any conditions, and at fly-ins like Clinton or Oshkosh I could recharge each day. I found that at Clinton I could get by most of the time without running the humidifier, so the battery would last quite a bit longer. But unless the relative humidity is very high like it was a Clinton, I can't tolerate using a CPAP without a humidifier. Then I discovered this CPAP [ cpap.com]. It's expensive but has two major advantages: First, it's a whole lot smaller and lighter. Second, it has an ingenious humidification system that uses a lightweight waterless cartridge in the hose that somehow captures the water vapor in exhaled air and uses it to humidify the inhaled air. It works very well. Without a heated humidifier, the power consumption is much less than the standard CPAP. Unfortunately, it requires 24 volts so I bought and use the optional high efficiency voltage converter which weighs just a few more ounces. Although you can use a 24 volt battery directly, operation from 12 volts nominal provides a lot more flexibility for batteries and charging. Consumption is a little over 3 Ah/night from a 12 volt battery so a 10 Ah battery will run it for about three nights -- enough for most overnight fly-ins -- without recharging. I use the small CPAP for all traveling because of its small size and weight. I've also insisted on using distilled water in my main CPAP so the small one also eliminates the need to carry and/or obtain distilled water. At Clinton I just charged the battery during the day in the FBO. On my first time at Oshkosh I used the charging station near the showers. The problem with that was having to stick around for several hours and babysit -- those batteries are expensive and, although there's very little risk of an unattended one being taken, I'd be without a CPAP for the rest of the time if it was. So when I went to Oshkosh a second time -- with my small CPAP -- I brought along a 50 watt foldable solar panel and put it on top of the airplane, running wires inside through the seal and solar charging the battery during the day. I was there for nearly a week and each day recharged the 10 Ah CPAP battery, my son's and my computers, a small lantern, a cell phone power bank, and various other gadgets each day without a single trip to the charging station. We charged our cell phones from the power bank at night. I could have gotten by with a smaller battery for the CPAP, but the extra capacity would have allowed us to run for a couple of extra days without direct sun if it clouded up (which it didn't, except briefly) and to recharge cell phones and the like. Send me a PM if you'd like any more details. Roy
States where I've landed my 150 | | | | | Joined: Feb 2004 Posts: 68 Likes: 12 Member | | Member Joined: Feb 2004 Posts: 68 Likes: 12 | Just for an update, the c-pap battery I got from Ron 20 worked great! It lasted both nights without recharging. My air mattress didn't work as well, but I survived pretty comfortably regardless. Just lost a little air each night
| | 2 members like this:
Brian Crane, Ron Twente | | | | | Joined: Jul 2013 Posts: 7,136 Likes: 1313 Member/5000+posts! | | Member/5000+posts! Joined: Jul 2013 Posts: 7,136 Likes: 1313 | On a slight tangent - The doc said that they're looking at using a CPAP instead of supplemental oxygen for some flight at least in the low teens because it forces the pilot to inhale enough oxygen to appropriately oxygenate the blood. There are CPAP units that will run off of the aircraft's power.
This sounds interesting to me as it would also be a way to get the needed oxygen without having to carry around an oxygen tank.
Wondering if anyone else has heard or seen anything on this use of CPAP units? Rick, very interesting! I believe it’s ventilation of CO2 that drives most respiration, not hypoxia. In other words our body doesn’t wait until it’s hypoxemic before you feel the need to breathe which is good. The brain cells do not tolerate lack of oxygen long before they suffer permanent injury. I guess those high flyers are ventilating well, so they breath the rate and depth they would on the ground. With the low oxygen mix up high, it’s not enough.
Geoff ![[Linked Image from visitedstatesmap.com]](https://visitedstatesmap.com/image/COILIAKSMONEOKWI92f3b8323dc722fe56e40c90c1f11690363026sm.jpg) N10473, the canary Huh I don't know | | | | | Joined: Mar 2004 Posts: 12,629 Likes: 573 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,629 Likes: 573 | On a slight tangent - The doc said that they're looking at using a CPAP instead of supplemental oxygen for some flight at least in the low teens because it forces the pilot to inhale enough oxygen to appropriately oxygenate the blood. There are CPAP units that will run off of the aircraft's power.
Wondering if anyone else has heard or seen anything on this use of CPAP units? Rick, very interesting! I believe it’s ventilation of CO2 that drives most respiration, not hypoxia. In other words our body doesn’t wait until it’s hypoxemic before you feel the need to breathe which is good. The brain cells do not tolerate lack of oxygen long before they suffer permanent injury. I guess those high flyers are ventilating well, so they breath the rate and depth they would on the ground. With the low oxygen mix up high, it’s not enough. Continuous positive airway pressure (CPAP) is a form of positive airway pressure (PAP) ventilation in which a constant level of pressure greater than atmospheric pressure is continuously applied to the upper respiratory tract of a person. Interesting. The same idea as aircraft pressurization except on an individual basis? How much additional pressure over atmospheric pressure can a CPAP machine provide? Aren’t most pressurized aircraft pressurized to 8psi which provides an 8000 foot pressure altitude inside the cabin at typical cruising altitude? I think the 787 has a higher pressurization level, at least that is what I seem to remember from some marketing stuff.
David Rowland 7CO0 | | | | | Joined: Jan 2008 Posts: 7,692 Likes: 799 Member/7500+posts | | Member/7500+posts Joined: Jan 2008 Posts: 7,692 Likes: 799 | In most pressurized jet aircraft, the pressurization is on a schedule.
Example, if you are at FL350 your cabin pressure will be about 5000 ft.
If you are FL310 your cabin will be at about 3500 ft.
If you are at FL410 your cabin will be at about 8000 ft.
Those are examples that I remember off the top of my head from teaching and flying for 20 plus years.
Ron "20" A&P/IA 1976 Cessna 150M - N820ST St. Charles Regional Airport KSET Fly Safe... Fly Often... Super Bowl IV - LIV - LVII - LVIII CHAMPION Kansas City Chiefs! 2019 Stanley Cup Champion St. Louis BLUES! | | | | | Joined: Jul 2013 Posts: 7,136 Likes: 1313 Member/5000+posts! | | Member/5000+posts! Joined: Jul 2013 Posts: 7,136 Likes: 1313 | Rick, very interesting! I believe it’s ventilation of CO2 that drives most respiration, not hypoxia. In other words our body doesn’t wait until it’s hypoxemic before you feel the need to breathe which is good. The brain cells do not tolerate lack of oxygen long before they suffer permanent injury. I guess those high flyers are ventilating well, so they breath the rate and depth they would on the ground. With the low oxygen mix up high, it’s not enough. Continuous positive airway pressure (CPAP) is a form of positive airway pressure (PAP) ventilation in which a constant level of pressure greater than atmospheric pressure is continuously applied to the upper respiratory tract of a person. Interesting. The same idea as aircraft pressurization except on an individual basis? How much additional pressure over atmospheric pressure can a CPAP machine provide? Aren’t most pressurized aircraft pressurized to 8psi which provides an 8000 foot pressure altitude inside the cabin at typical cruising altitude? I think the 787 has a higher pressurization level, at least that is what I seem to remember from some marketing stuff. David, I think the biggest difference between CPAP and a pressurized cabin is in the pressurized cabin you have artificial pressure both inside and outside the lungs. You’re submersed in the pressure bath, so to speak. With CPAP, your body is exposed to one pressure but your airway is given a higher one. The machine blows it in to inflate your lungs, not requiring the negative pressure usually required to inhale.
Geoff ![[Linked Image from visitedstatesmap.com]](https://visitedstatesmap.com/image/COILIAKSMONEOKWI92f3b8323dc722fe56e40c90c1f11690363026sm.jpg) N10473, the canary Huh I don't know | | 1 member likes this:
Ron Twente | | |
