#666080 04/24/24 11:56 PM
I'm thinking of attending this year. I assume we should bring our own ropes and chocks. Do we need to provide our own anchors or will the airport have enough lugs for everyone?
N1270Q 1971 C150L
Wings Field KLOM
Jon MacGahan #666084 04/25/24 12:32 AM
Hi John, It's recommended that you bring your own anchors unless you want to use the "Dog Screw" anchors.
Those we have plenty of and it is what I use every year.
Definitely bring your own ropes.
3 members like this: John Trolinger, Ron Twente, Jon MacGahan
Jon MacGahan #666098 04/25/24 11:20 AM
Jon,
Just to make it clear, everyone at Clinton parks on the grass so you will need tie downs and ropes. As Ron noted, we have plenty of the screw type tie downs, but no rope.
I use "The Claw" system when I'm in Clinton.
I certainly hope you make the trip to Clinton. It's a lot of fun and will most likely be your first of many trips to Clinton.
1 member likes this: Jon MacGahan
Jon MacGahan #666119 04/25/24 02:06 PM
https://slidedown.com/
This is a great tie down rope system to use.
Also. I use these anchors
https://flyties.com/
2 members like this: John Trolinger, William Lund
Jon MacGahan #666137 04/25/24 07:18 PM
I use "the claw' but substitute ratchet straps for the rope
Charlie Moe
1966F N8750G
Lillybelle
Jon MacGahan #666172 04/26/24 01:38 PM
I use "the Claw" and "Slide Downs" for the ropes. This works very well in the Clinton dirt and at Oshkosh if you go there too.
N8395M 1970 A150K
Jon MacGahan #666193 04/27/24 01:20 AM
I use anchors that were made by club member Norval Gruver, with chains from a central ring to the big nail anchors and a rope from the ring to the wing. I guess I like tying knots. Probably should try the slide down ties.
N10473, the canary
Geoff Vincent #666202 04/27/24 09:35 AM
I know a lot of folks likes them - but the sailor in me tells you to stick with knots!! Well tied knots don't vibrate loose in a breeze. I'm afraid I've seen too many instances where the slides do unless backed by a knot. from a couple of years ago:
https://www.cessna150152.com/forum/ubbthreads.php/topics/644791/re-tie-down-rope.html#Post644791
and
https://www.cessna150152.com/forum/ubbthreads.php/topics/644809/re-tie-down-rope.html#Post644809
3 members like this: Wayne Schlueter, Geoff Vincent, Ken
