#674899 12/10/24 02:20 PM
Looking to do some panel updates. Replace engine instruments and some of the switches.
Anyone on this site happen to know who could cut a new aluminum right panel for a C150F?
Thanks
V
V Offline
I came here looking for the same. Mine is also an F model.
If anyone can do this, looks like two customers already
My goal:
Replace fuses with CB’s
Replace push/pull switches with toggles as appropriate
Clean up broken plastic
I have an A&P that can do the work, but doesn’t cut panels
Thanks
Your best bet may be to find a local machine shop that has CNC capabilities. Back in 2018, when I redid my panels, a local fellow on my field had a CNC plasma cutter. I gave him a rough draft of what I needed and he cut a "draft" out of cheap thin metal. Once adjustments were made, he cut a final panel.
N8395M 1970 A150K
