Page 2 of 3 1 2 3
Originally Posted by Eric Olson
Could one just drain all useable fuel and then add fuel one gallon each side, so two gallons at a time, and mark a wooden stick in one gallon increments? I would think this should work with the airplane sitting in a wings level position. If one gallon is added in each tank and a few moments allowed to self level, it should be very accurate. You could close the fuel valve to stop the tanks from feeding each other and the fuel self leveling, throwing off the readings. Then just fill one tank and take the measurements. But, it might be more accurate, no chance of fuel valve allowing some internal leakage, if each tank was filled one gallon at a time and they self level through the fuel valve.
Am I missing something that would make this idea not work?
You could drain the useable fuel through the belly drain. It would take a while, but it could be done.
I don't understand your definition of "self level." Fuel in the tank is always level. But if you mean the two tanks seeking level with each other, that takes a bit longer. BTW: closing the Fuel Shutoff Valve will not stop the tanks from feeding each other. It only stops fuel from leaving the tanks. They will still vent between each other because they are connected upstream of the valve.
Now, if you get two guys, two ladders, two one-gallon fuel containers, two dipsticks, and they add one gallon to each tank at the same time, they will be level. They could mark each tank and you could compare the results.
Also, if the airplane is completely drained down to unusable fuel thru the belly drain, part of that first gallon will go into the line to the drain. It won't be much, but you will not have a true "one gallon" in the tank.
I use a 150 Fuelstick & the 152 Fuelhawk, they both seem to read the same.
https://www.aircraftspruce.com/catalog/pnpages/05-12341.php
Als,o check out this newsletter, it has an article with all the math done for making one
https://www.cessna150152.com/forum/ubbthreads.php/ubb/download/Number/65512/filename/200305.pdf
N21966 - 1973 150L
[Linked Image from ]
1 member likes this: David Engle
I am using a glass calibrated tube to measure fuel in each tank showing up to 12 gallons from Sportys that is supposed to be OK for the 150. I have recently purchased a 1975 150M. When I use the tube and it says 8 gallons each side - is that usable or unusable fuel I am looking at. (16 gallons - 3.5 = 12.5 gallons = 12.5 usable) or is it (16 gallon usable)? I am finding conflicting info on the internet and the POH tells me 26 total with 22.5 usable but doesn't answer my question. Thanks
The 150 is 26Gal total (13per side) but only 22.5 is usable. The POH is the go to source.
If you fill your tanks to the bottom of the filler neck and measure with the tube you bought from Sportys and it reads just over 11 gal in each tank then that is usable. If it reads 13 each side then it is total and you need to subtract 1.75 each side to get useful amount.
I don't know how the Sporty's fuel stick is marked, but can we go by this: if the 1-gal mark is very near the bottom end of the stick then it indicates actual fuel level, if it's away from the bottom of the stick (i.e. has a blank area) then it indicates usable fuel level?
Thanks guys. Makes sense and I appreciate the help.
Geez, after all these years and thousands of 150's flying....there is currently NOT a specific-made 150 dip stick?!
SPORTY's....get to work!
Mike Marra
1977 C-150M N714AJ
Carlisle, PA. Member; Mar '07
After doing some measuring and math I can verify that the FUELHAWK C-152/12 gal fuel gauge (glass tube) I'm using gives me usable fuel on my 1975 150M.
2 members like this: Mike Marra, Joseph B
Steven, yes it does, but is not accurate. And what is the purpose of dipping just to get an inaccurate reading? I also use the FUELHAWK C-152 dip stick tube but to get an accurate reading it needs to be modified. Do this the next time you fuel up. Dip your tanks first to see how much fuel remains. Let's say they read 5 gallons each so you should have 10 gal usable remaining. If that is correct you would need 12.5 gal to top off. Top it off and see what it takes. I will make a bet it is off by about 2.5 gal. There are ways to correct that but try this experiment first. Also a little tip, if when you dip your tanks and the reading does not hold steady, first moisten your finger that you use on top of the tube.....................Jay
When the flak gets heavy the target’s close by.
Jay: Will definitely do as suggested and the moist finger tip is appreciated. this club and forum has been a tremendous help to me. Thanks to all.
Page 2 of 3 1 2 3
