#67853 11/13/06 02:55 PM
I saw this plane for sale on my field. Mason Michigan KTEW.
The owner is a member of my EAA chapter. 5335 TT 405 SMOH
$ 18,500 November 2005 annual. (517)333-4531 Owners name is Drew.
Dick Riisberg
69280-Airplanes 11-6-06 003r.jpg (0 Bytes, 142 downloads)
X
I own a 1970 150K. This one is at least a 1972 150L, evidenced by the longer dorsal fin, fiberglass single bulb cowl, and no landing lights in the wing.
Carl
You are correct. I based my information on the for sale sign that said 1970. The data plate shows the model as 150L.
Dick Riisberg
X
E
E Offline
From the FAA registry:
N1250Q is Assigned
Aircraft Description
Serial Number 15072550 Type Registration Corporation
Manufacturer Name CESSNA
Model 150L Status Valid
Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating
Pending Number Change None Dealer No
Date Change Authorized None Mode S Code 50064254
MFR Year 1971 Fractional Owner NO
She was first certified in late 1971, but by serial number, sold new by Cessna as a 1972 year model.
For record keeping purposes, the FAA only recognizes the year of manufacture, not the manufacturer's year model.
Dick - I tried the number posted for this plane and just got a fax tone, is there another number? Also, do you know anything else about the plane? I'm currently looking to buy a 150 and this one looks kind of interesting. Thanks, Scott
Scott
I sent you a private message. I will try to get a better phone number.
Dick
X
Scott
I just tried the phone number 517-333-4531 and talked with Drew. It is a good number (phone and fax machine).
Dick
X
