| | Joined: Dec 2003 Posts: 2,134 Member/1500+posts | | Member/1500+posts Joined: Dec 2003 Posts: 2,134 |
Tim '76 C-150M, San Antonio
| | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Ahhhhhh, the infamous 'H' motor. Such an excellent boat anchor.  | | | | | Joined: Dec 2003 Posts: 14,946 Likes: 672 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Dec 2003 Posts: 14,946 Likes: 672 | The O-320-H2AD taught Lycoming to never again introduce an engine with an "AD" in the model name....  Because of the paperwork hassle this airplane would almost best be sold for parts. Or trade the O-320 for a good O-200 and turn it back into a normal 150. Alternatively, a buyer in Canada could de-certify it and fly under their owner-maintenance program. That would be neat!
| | | | | Joined: Jan 2006 Posts: 3,657 Member/2500+posts | | Member/2500+posts Joined: Jan 2006 Posts: 3,657 | I quote from the ad: Not H2AD no paper work for engine change
log books are not up todate no recent annual
aircraft is together engine can be run This sounds like a good deal to walk away from!
Pat
| | | | | Joined: Jan 2004 Posts: 4,968 Member/2500+posts | | Member/2500+posts Joined: Jan 2004 Posts: 4,968 | Are the H2AD mounts the same as the E2D and other allowable engines? Could be an engine core swap if the STC is there as it indicates, but as Patrick says....with all of these "non-certified" issues, you have to wonder what else is lurking so...
don't walk....RUN!!!!!!!!!!!!!!!!! | | | | | Joined: Jan 2007 Posts: 263 Likes: 1 Member/250+posts | | Member/250+posts Joined: Jan 2007 Posts: 263 Likes: 1 | Alternatively, a buyer in Canada could de-certify it and fly under their owner-maintenance program. That would be neat! Ya...just make sure there's no existing liens on the airplane from the freakn''60's on it. I just hear the word "decertify" and I start to cringe.
1959 150
| | | | | Joined: Feb 2004 Posts: 1,015 Member/1000+posts | | Member/1000+posts Joined: Feb 2004 Posts: 1,015 | Check the Regs. but I think an aircraft has to be certified first and then put in the 'owner maintenance' category, in Canada. | | | | | Joined: Jan 2006 Posts: 3,657 Member/2500+posts | | Member/2500+posts Joined: Jan 2006 Posts: 3,657 | Sounds like our Canadian friends will have at least as many headaches as us Yanks getting that plane legal again.
Pat
