Page 1 of 5 1 2 3 4 5
Are there any alternative sources for an approved spinner and forward spinner bulkhead for a 150L other than Cessna?
I believe they're financing the "Columbia" deal thru the aftermarket sales of these items. mad sick
Dave "ViKing" Monskey Living the Dream, Don't Wake Me Up!!!
1971 150L N6580G
I was going to suggest going to a Skull Cap. [aircraftspruce.com] But then I noticed that you had an L model. frown
I just saw that Wag Aero had some spinners for sale.
Pat
The parts catalog refers you to Cessna Single Engine Bulletin SE70-1, affecting your airplane (and mine). There are some UNAPPROVED copies on the market, so be careful what you buy. Read the codes!
That spinner in the Wag-Aero catalogue isn't an approved part. I'm told it has to be an approved part to be installed on a certified aircraft. That spinner can be installed on an "experimental" aircraft...so I'm told. frown
What if I'm doing an experiment on my aircraft... confused
1971 150L N6580G
Go for it Friends don't tell. I got one off a 75M with a crack in it if that will help. Its been welded but not ground down to remove the evidence.
Ken Online: Content
Is the spinner and associated plates optional equipment on your plane. I know it is on my 66 model. While some people don't like it, I like being spinnerless and pantless!
Ken Yates
Clarke County MS
N4505U
150/150D
Who is ultimately responsible for the airworthiness of the aircraft?
Pilot / Owner correct?
"I have inspected this spinner assembly, (P/N, S/N), and have determined this assembly to be airworthy for use on my personal use aircraft, (S/N), registered in my name."
Signed by the owner/pilot along with his certification number.
Bill,
Show me which reg. allows you to do that?
-Brian
Bill,
-Brian
Sec. 91.3 - Responsibility and authority of the pilot in command.
(a) The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft.
FAR 91.7 - Civil aircraft airworthiness
(a) No person may operate a civil aircraft unless it is in an airworthy condition.
(b) The pilot in command of a civil aircraft is responsible for determining whether that aircraft is in condition for safe flight. The pilot in command shall discontinue the flight when unairworthy mechanical, electrical, or structural conditions occur.
