Anyone have a lead on a good serviceable Sensenich 72CKS6-0-54 propeller. I have the spinner/spacer. Just need the prop.
W
W Offline
Try a place called Tiffin Aire. I just purchased the whole STC for the 152. They were very nice, responsive and quick.
There is a 48" 72CK-0-48 on ebay. It was sold 2 weeks ago for 240$ and now it's been re-listed. I know you will have to re-pitch to 54" and re-use your bolt and spacer, but it might be a good deal for you anyway...
http://cgi.ebay.com/ebaymotors/SENS...439QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Quebec City, Canada
C150L 150HP C-FRED
If you keep an eye on the salvage yards, eventually 80Q's Sensenich prop (forget the pitch) and spinner will be available. Rumor has it as having been bought.
And if looking to do the full 125 Hp upgrade, I have all the NWAirMods STC's for the prop & engine available, plus the baffle kit - never "installed." And a spare engine to overhaul for it, too.
'75 C150M/150 . N45350
What does the "S6" in the part number mean? Does the actual stamping on a 72CKS6-0-54 propeller have the S6 stamped on the hub?
I found the answer. S means spacer and 6 means 1.5" thick.
Konrad,
I sent you a PM!
Terry
TD
