#19559 06/14/05 06:37 PM
I was wondering if anyone has had experience with Max Haufe, instrument rebuilders from Sarasota, Fla. I've sent my DG to them twice & it still has a lot of precession! The second time around they claimed a screw came loose but it still acts up.
Thanks
Gerry #19560 06/21/05 12:03 AM
I'm assuming you are comparing your newly overhauled DG with your airplanes wet compass. As it is possible that the quality of the overhaul could be questioned, don't rule out problems with the wet compass. I experienced a similar problem years ago with the HSI in a C-414A. We sent the instrument back to the instrument shop repeatedly with pilot complaints of precessing, only to find that the wet compass was to blame .
You might want to check when your compass was last overhauled and/or swung. Don't hold me to it, but I think that Cessna requires and/or recommends a compass swing every two years. Not a bad idea to know what's going on there anyway. Good luck !!
John
7B6
CT
John Ludemann
1975 C150M
N66768
Member since August 8, 2003
Lifetime Member since 2009
"Official East Coast OutKast"
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." - Leonardo da Vinci
