| | Joined: Aug 2005 Posts: 2,525 Member/2500+posts | | Member/2500+posts Joined: Aug 2005 Posts: 2,525 | Well,, I just purchased 100 roll pins for window arm levers,
Part number is NAS561P3-8,, if anyone needs one,, I only need 2 of them,,
| | | | | Joined: Nov 2006 Posts: 2,362 Member/1500+posts | | Member/1500+posts Joined: Nov 2006 Posts: 2,362 | I'll buy 2! mine keep working there way out, as part of my preflight I have to push them in with a pair of pliers.
John | | | | | Joined: Aug 2005 Posts: 2,525 Member/2500+posts | | Member/2500+posts Joined: Aug 2005 Posts: 2,525 | John, you and me have the same problem,, I'm tired of having to "push" them back in all the time,, I have this vision,, of them falling out in flight,, Anyways, I really don't intend selling them,, but you can have 2 of them, I got a steal on the package,, a penny per piece,, but,, a Tim Horton's triple/triple works for me  Anyways,, send me a PM with your mailing address and I'm sure they'll find their way into your window arm,,
| | | | | Joined: Jun 2006 Posts: 1,024 Likes: 1 Member/1000+posts | | Member/1000+posts Joined: Jun 2006 Posts: 1,024 Likes: 1 | If they are working their way out, install the new pins then take a centre punch (automatic or old school) and place two small marks on close to either side of the pin to stake the pin into place. The surrounding metal of the arm should mush over slightly to hold the pin. You could also run some thin lockwire through the centre of the pin and wrap it around the arm to hold the pin in place.
John 150-61401 C-FUUE
| | | | | Joined: Aug 2005 Posts: 2,525 Member/2500+posts | | Member/2500+posts Joined: Aug 2005 Posts: 2,525 | John, That's a good idea to score the pin a bit, to provide grip to the pin.
As far as wiring the thing in,, that would work well also,, might look a bit gaudy mind you but practical,
Typically roll pins are good for a few insertions,, and then should be turfed. I've no idea how many times mine might of been removed and put back in. It's like re-using bolts and or nuts, over and over again. Eventually they've outlived there usefulness and should just be replaced.
| | | | | Joined: Jun 2006 Posts: 1,024 Likes: 1 Member/1000+posts | | Member/1000+posts Joined: Jun 2006 Posts: 1,024 Likes: 1 | Sorry, I don't think I was clear. What you want to do to stake the roll pin is to take a centre punch (I usually use my automatic one) and locate the point of it about 1/8th of an inch from the edge of the hole on the arm and create a small indentation. If done right, the hole be ever so slightly "mashed", so that the arm material can grip the roll pin securely. Same idea for the spherical bearing used in the elevator control bellcrank.
| | | | | Joined: Aug 2005 Posts: 2,525 Member/2500+posts | | Member/2500+posts Joined: Aug 2005 Posts: 2,525 | Aww, now I understand. That makes a lot of sense. That'll be the first thing that my pins see,, a punch,, and hey, if I wreck one,, of got a whole bag full to play with.
Thanks John,,
| | | | | Joined: Mar 2004 Posts: 1,698 Member/1500+posts | | Member/1500+posts Joined: Mar 2004 Posts: 1,698 | Lionel, Is it possible for me to get two of them? I would really appreciate it.
Wayne "Plane Crazy"
| | | | | Joined: Aug 2005 Posts: 2,525 Member/2500+posts | | Member/2500+posts Joined: Aug 2005 Posts: 2,525 | Anyone else interested in a few roll pins?
| | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Sure, I'll take 4... 2 for now and 2 for spares!
Speedmaster Signs, Inc. 1132 13th St Columbus, GA 31901 USA
Thanx, Lionel!
