Does anyone have a rear fuel tank fitting available? This is the one with the mesh strainer soldered into it that the line from the cabin wing root rear fuel tube threads onto. It threads into the welded aluminium boss on the fuel tank. Mine leaks and is a little "rounded". I may have to get medieval to get it removed. C-152. I think the 150 has the same. Thanks.
Hi Jason, do you still need the screen/fitting for your fuel tank, do have one in like new condition
Cheers
RJ
Just yesterday I found one. I bought it. Thank you so much for the reply though. Jason
