#243796 01/20/10 05:32 PM
The MX-11 Comm is designed as a slide in replacement for the Narco Com 11, Com 11B, Com 111, Com 111B, and Com 120. The unit will replace the com 10 and Com 110 when the Nav 10 and Nav 110 are not used in the system.
* Frequency Range: 118.000 to 136.975 in 25 KHz increments
* Frequency Stability: +/- .003%, -20C to 50C
* Transmitter Power: 8 watts minimum
* Modulation: 85% minimum with limiting at 90%
* Sidetone: Adjustable to 4 mw into 500 OHMs
* Receiver Sensitivity: 1.5uV (soft) for 6 db s+n/n
* Comm Selectivity: 3 db @ +/- 7.5 KHz; 65 db @ +/- 17.5 KHz; 90 db @ +/- 25 KHz
* Squelch: Noise adaptive squelch with manual override
* Audio Output: 5 watts into a 4 ohm speaker; 40 mw into a 500 ohm headphones
* Weight: 3.13 lbs.
* Power: 14/28 volts @ 6/3 amp in transmit
As removed in great working condition with tray...
Can get a 8130-3 in a week if needed...otherwise full refund in 30 days if not satisfied. $500.00 Asking
Item has been SOLD...thanks.
