Hello,
Looking for two control yokes for a C-150A (1961). Can be the handles only - without the shaft. One broke, and I want to replace both with a matching set.
Thanks!
If you have the squarish "bow tie" yokes, and one broke, then you must have the plastic ones. These were covered in what was originally proposed to be an airworthiness directive, but later became an SAIB (Special Airworthiness Information Bulletin) instead. (which notably does not show up in the FAA's index of SAIBs, I found it with Google) There is a Metal/plastic coated version of this yoke that you need to look for.
The yoke and shaft are not separable and should be replaced as a unit.
The earlier oval underhung yokes are metal with a plastic coating and would also work. I suspect the later ramshorn yokes would be too high for comfort, though that is just a guess. Your IA might have some issues with legality of installing them, also.
Charles
