Before I go through the time and trouble of converting the clock and APU plug fuses to circuit breakers, I wanted to see if anyone here had some spares lying around.
I need a 5-amp fuse and a 1-amp fuse.
I checked Barney's post but he doesn't have any this small.
I will look around at work and see what I can find.
I bought a box of 5 Littelfuse 4AG 1A fuses from a club member a few years ago. I think they look Like These [ebay.com] . If that's what you need, I can give you one.
I think I have a few of those.
Might be a day or 2 before I can check at the hangar.
Philip Mitchell
Attorney, CFI, A&P
N150BP C150L
Question, is there an issue with using just any fuse that is the correct amperage and voltage? Before I changed over the circuit breakers... the fuses I found in Delmar were shall we say... a diverse group. LOL Mechanically speaking... what would the performance difference be ??
Blue Skies,
Gene
N5977J
You bet your sweet bippy there is. There is the issue of a physical size difference. The 4AG series fuses are commonly specified in older aircraft. About 30 years ago Buss superseded them to the obsolete AGS series fuse. The barrel diameter of our old fuses is 9/32". Fuses from your local auto parts store are 1/4" diameter. An under sized fuse will lead to a very hot generator or alternator fuse cap due to internal resistance caused by the loose fit of auto type fuses.
Yes,Gene, there is a big difference. wink
IMPORTANT: This email is intended for the use of the individual addressee(s) named above and may contain information that is confidential, privileged or unsuitable for overly sensitive persons with low self-esteem, no sense of humour or irrational religious beliefs. If you are not the intended recipient, any dissemination, distribution or copying of this email is not authorised (either explicitly or implicitly) and constitutes an irritating social faux pas. Unless the word absquatulation has been used in its correct context somewhere other than in this warning, it does not have any legal or grammatical use and may be ignored. No animals were harmed in the transmission of this email, although the yorkshire terrier next door is living on borrowed time, let me tell you. Those of you with an overwhelming fear of the unknown will be gratified to learn that there is no hidden message revealed by reading this warning backwards, so just ignore that Alert Notice from Microsoft: However, by pouring a complete circle of salt around yourself and your computer you
can ensure that no harm befalls you and your pets. If you have received this email in error, please add some nutmeg and egg whites and place it in a warm oven for 40 minutes. Whisk briefly and let it stand for 2 hours before icing.
McFarlane has them. Link [mcfarlaneaviation.com]
1968 150H N5005
1969 Pitts S-1C
1970 150H Super Heavy wink
Yup, they do, but they sell them in lots of 5.
In my particular instance I don't need that many. If it came to buying McFarlane I'd just as soon apply that money towards buying a circuit breaker. I already have a 5-amp breaker, just need a 1-amp. But I don't want to go through the trouble of installing them right now (they're mounted in the tailcone, wedged between the between battery box and the fuselage skin).
Thanks - mine doesn't look like that. The IPC doesn't specify a Slo-Blo fuse for the clock, so I don't think I should use it.
As it is somebody put in a 1-1/2 amp fuse before me (who checks *that* on a pre-buy?)
Got 'em Kirk. see PM.
