| | Joined: Mar 2004 Posts: 16,296 Likes: 1220 Member/15,000 posts | | Member/15,000 posts Joined: Mar 2004 Posts: 16,296 Likes: 1220 | My 152 goes thru beacon bulbs way too often. One of the contacts in the bulb socket has a bad spring and makes a bad connection with the bulb. This generates heat and the contact on the bulb melts away. So if anyone that has replaced their beacon for a self contained LED beacon and happens to have an old beacon assembly laying around that they wouldn't mind parting with, let me know.
Thanks
Ron Stewart N5282B KSFZ | | | | | Joined: Dec 2003 Posts: 15,063 Likes: 763 Member/15,000 posts | | Member/15,000 posts Joined: Dec 2003 Posts: 15,063 Likes: 763 | Just for you, I'll make you a deal. You buy me an LED tail beacon and I'll GIVE you, for free, my old Cessna, factory-original tail beacon. I'll even throw in a fresh bulb.
| | | | | Joined: Dec 2003 Posts: 26,120 Likes: 1292 Member/25,000 posts | | Member/25,000 posts Joined: Dec 2003 Posts: 26,120 Likes: 1292 | Just for you, I'll make you a deal... Have you ever thought about becoming a car salesman, Kirk?  | | | | | Joined: Mar 2004 Posts: 16,296 Likes: 1220 Member/15,000 posts | | Member/15,000 posts Joined: Mar 2004 Posts: 16,296 Likes: 1220 | Thanks but I don't need the bulb.
Ron Stewart N5282B KSFZ | | | | | Joined: Mar 2004 Posts: 12,629 Likes: 573 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,629 Likes: 573 | Just for you, I'll make you a deal... Have you ever thought about becoming a used car salesman, Kirk?  There, fixed it for you.
David Rowland 7CO0 | | | | | Joined: Feb 2004 Posts: 115 Likes: 2 Member/100+posts | | Member/100+posts Joined: Feb 2004 Posts: 115 Likes: 2 | Ron, if nobody can help you out here, Aircraft Spruce should have what you need: AEROFLASH SOCKET & PLATE ASSY P/N 073-0021 http://www.aircraftspruce.com/pdf/2016Individual/Cat16620.pdf$23.50 new I replaced mine several years ago due to similar issues to what you are experiencing and haven't had to replace the lamp since....well worth it IMHO. | | | | | Joined: Mar 2004 Posts: 16,296 Likes: 1220 Member/15,000 posts | | Member/15,000 posts Joined: Mar 2004 Posts: 16,296 Likes: 1220 | Thanks Mitchell. That's just what I am looking for.
Ron Stewart N5282B KSFZ | | | | | Joined: Nov 2007 Posts: 535 Likes: 8 Member/500+posts | | Member/500+posts Joined: Nov 2007 Posts: 535 Likes: 8 | | | |
