Correct me if I'm wrong here but I believe only the 65/66 doors will fit.64 and earlier are smaller and 67 and newer are bowed out and only have 2 hinges.
Sure, I've got them.... but what's wrong with the ones you've got?
Nothing's wrong with the ones I have. I would like two spares to install dome windows on so I can switch them out when I want and maybe sell them if I don't like the dome windows. It all depends on what a spare set of doors might cost.
All of the straight-tails ('59 through '65) use the same door. Borrowed from the Cessna 120/140, but with three hinges instead of two. These doors are somewhat trapezoidal in shape.
The slant-tails, '66 and up, have a larger, rectangular, door that uses only two hinges.
1966 has a unique door - larger than the earlier door, but not bowed out like the later door.
Since you're going to replace the windows anyway, you'll be able to pick up a ratty pair of doors with broken windows fairly cheap. Price goes along with opportunity, though.
So, do you have a ratty pair of doors with broken windows fairly cheap?
A friend of mine picked up a pile of them from last February's consignment auction to resell as "art". I stripped window latches, door handles, and hinges from a few of the square doors in his pile, because I don't have any older 150s with the angled doors. He has been slinging them at craft fairs as wall hangers. http://www.wyldebyrd.com
