#528146 02/18/17 07:07 PM
I need ether the whole deal or parts, like the fork, the 6" wheel and the axle. I'm still trying to figure out how much of my regular gear can be reused on the HD.
1968 150H N5005
1969 Pitts S-1C
1970 150H Super Heavy wink
Different scissors and collars. I'll fetch the list next week. Easy common switch. Form and W/B.
Dearest, let me explain you why no one is taking you seriously. It takes just few minutes to check facts nowadays. For example, the scissors of the H model and those of the heavy duty nose gear are THE SAME PART NUMBER. The collar is different between the H model and serial numbers before 15064532. However, the standard and heavy duty nose gears of the earlier models use the same collar. So essentially, you are wrong again.
If I may ask, what is the reason you try to answer questions that you clearly don't understand or know about?
1968 150H N5005
1969 Pitts S-1C
