#555783 02/12/18 11:30 PM
Hi All,
I recently had a radio failure that I discovered was caused by a fuse element that simply broke. That prompted me to check the continuity of my spare fuses. And guess what? My spare 15A SLO-BLO looked great, but was also defective.
So,
I'm wondering if anyone happens to have an AGS 15A SLO-BLO fuse (for flaps) that I could buy from them?
Thanks, in advance, for whatever assistance you could provide,
Steve Amesbury
I have a package of ags/mdm 15 amp slow blow. They are different than what is in my 150 for flaps it has a timed fuse in it. I don’t know the difference or if they are interchangeable.
"Gravity Always Wins"
Thanks guys!
Mcfarlane didn't have them. Elliott's, though, does appear to have a substitute. I ordered them and will let you know if they really do match.
Thanks, again!
Steve A.
Dave - If the fuses are 9/32" x 1-1/4" they are probably correct. The older AG (auto glass) fuses were replaced with ceramic tubes. Check the markings on the end barrel. Are your fuse holders original?
Got the fuses from Elliott's. They are made by "littlefuse" and appear to be fine. The size is the same, thay're stamped 15A and there is a little sticker on them that says that they're Slo-Blo.
Yeaaah!
