Page 2 of 3 1 2 3
Is the Pennsylvania Dutchess still available?
Bruce Bennett
Visited
She's gone.
Hi Matt-
I am based at DYL. I don't know the seller, but this plane is on a tie down near mine and I see it flying all the time. I second Ed's recommendation of P-Factor at Pennridge as a close option for a pre-buy. Joe Flury is there now and is a conservative and well respected A&P in the area. There are a couple of guys at Quakertown who are also well regarded.
Do you know who did the last annual?
- Jim
________________
1976 Cessna 150M
Yes it looks like joe Taylor has done the maintenance and annuals for the last year and a half.
Not familiar with that name. Any indication where he was located?
I flew last evening, and I was leaving the airport the Cessna you're looking at was departing. Probably a good sign that they trust the engine enough to fly it in the dark.
- Jim
________________
1976 Cessna 150M
I’m not sure where he is located. It looks like a Aulio A. Giron was the IA for the first annual. Leading edge aviation replaced a tire (can’t read the mechs name) and Philip s. Babb did the last annual.
Phil Babb owns P-Factor Aviation at Pennridge.
- Jim
________________
1976 Cessna 150M
Awesome. Thank you I tried giving them a call this morning but didn’t get ahold of anyone I will try again in a little while. Thanks
The guys at Pennridge (Joe and Phil) have a good reputation, but you'd probably be well served to have someone who has not previously worked on the plane do your pre-buy.
I think that the shop at Sky Manor N40 is also good (www.skymanorairrepair.com [skymanorairrepair.com]), although I've only really used them for avionics. N40 is only about 15nm from DYL.
- Jim
________________
1976 Cessna 150M
I believe I saw sky manor in there also lol I’ll check when I get a chance!!!
Page 2 of 3 1 2 3
