Brilliant idea on the temporary leg. Rather than weld it, I will see if I can fabricate a bolt on sleeve
I think two 3/16 or 1/4" steel plates with 5/16" or 3/8" bolts. Provided the holes place the bolts tangent to the gear leg sides and bolts torqued down I suspect it would work perfectly.
