WINTER IS COMING
You can't get these anymore.......
The LT 2-12 MH-300 features a heat sensor located near the air outlet that will shut off fuel to the burner if the preheater surface temperature exceeds safe levels. Other safety features include electronic Piezo igniter for clean, reliable ignition; safety shutoff valve which shuts off fuel flow if flame goes out; adjustable regulator for variable BTU output; and excess flow P.O.L. which limits the flow of fuel if there is a sudden surge due to a malfunction in the fuel line. The 10' power cord has alligator clips for quick attachment to a 12 volt D.C. source. A 5-foot fuel hose allows convenient connection to any LP-gas cylinder.
![[Linked Image]](https://www.cessna150152.com/forum/ubbthreads.php/ubb/download/Number/81474/filename/20231026_095849.jpg)
As shown in photograph with all original documentation. Hard Shell Carry Case.
Does not include the original 90 degree bend (you can get one at your local Home Depot / Lowes) and does not include the air delivery hose which you need to make up to suit your application/aircraft. See picture for how I did it. There are instructions in the documentation. I used AC Duct and an insulation sleeve from the home improvement store.
With a thick blanket over the cowl and no wind you can get the engine completely warmed through, oil thinned down and into "summer start" mode with about 30 mins heating.
Well looked after in storage box. Probably 40 preheats over 10 years. Almost looks new. Burner orifice recently cleaned (a 1/32" drill to remove carbon build up). Runs and heats great!
![[Linked Image]](https://www.cessna150152.com/forum/ubbthreads.php/ubb/download/Number/81475/filename/DSC02724.JPG)
Dimensions (L x W x H)
19.98 x 10.28 x 10.95 IN
Package Weight
21.5 LB
Heat at outlet
49000 Btu
Electrical Draw
4 Amps @ 12 VDC
$150 plus shipping of your choice. Cash / Check / PayPal (+5%)
