Selling Logitech sim flight system controls.
Price $150 and will ship within continental USA.
1) Yoke that is new
2) Throttle quadrant that is new (plugs into yoke)
3) Rudder pedals although not new have been used very little
Located in Evansville, IN
Yoke and throttle quadrant new in box. Whole system purchased from Sportys.
L
L Online: Content
Which model yoke, pedals and quadrant?
This bundle contains 2 items (may ship separately)
1 of Logitech G Pro Flight Rudder Pedals
2718
$179.99
Smooth and accurate self-centering rudder pedals add another layer of realistic control to your flight simulation setup
Whether you prefer the lighter response of a small aircraft or the more robust feel of a heavy jet, a simple twist of the Adjustable Tension Dial will have you flying your way.
Differential Toe Brakes deliver the full control you need when bringing your aircraft up to its stand on the runway
Platform Compatibility: Windows 7, 8, 8.1 and 10, Internet connection for optional software download
Technical Specifications: 9-bit Rudder axis, 7-bit Toe Brake axis, USB 2.0-compliant Dimensions (cm): 31x41x17 Weight: 2.3 kg
1 of Logitech G PRO Flight Yoke System, Professional Simulation Yoke and Throttle Quadrant, 3 Modes, 75 Programmable Controls, Configurable Knobs, Steel Shaft, USB, PC - Black
2720
$179.99
Realistic yoke controls offer an ideal setup for new pilots and help experienced pilots build muscle memory. In the Box : Flight Yoke with 5.9 ft (1.8m) USB Connector Cable, Flight Throttle Quadrant with 4.92 ft (1.5m), PS/2 Connector Cable, 2 Desk Clamps
Stainless Steel Yoke Shaft - Robust, smooth and accurate control of your virtual aircraft in flight simulators
POV Hat, 14 button controls, and 3-position mode switch offer at least 54 programmable controls, giving you most of your aircraft’s functions under your fingertips
2 position desk clamp provides mounting flexibility for a wide range of desks with a robust, secure clamping force to ensure your controls stay where you need them
Compatible with Windows 11/10/8.1/7. Requires optional software download for use with Microsoft Flight Simulator, FSX, X-Plane 10, and Prepar3D
I purchased these in January of this year from Sportys. Used them with X-Plane 12 and MSFS 2024 and worked good with both softwares. I had trouble this fall with the throttle quadrant and since the yoke and throttle quadrant come as a set Sportys said to send both back for repair or replacement. They chose to replace and sent me a new yoke and throttle quadrant which is still in the box and has never been hooked up or used. My life situation has changed and no longer need these.
A Offline
1) Yoke that is new
Hey Steven,
are these still available?
please pm me
I will take ‘em if they’re not already spoken for. I have a 10 yr old nephew who has the bug and flies the sim daily. He’d go nuts for this!
Lachlan:
Thanks for the inquiry however they are SOLD.
Steve
1 member likes this: Lachlan
