#70154 11/30/06 07:43 AM
I'm fixin to shop the salvage yards for an ASI for my '79 Aerobat, serial # A1520831 and was hoping someone might confirm i'm using the right part # which i see as #C661065-0216. Also before i start searching, can anyone recommend a place they've had good luck with regarding good pricing and customer service? Any help is much appreciated.
Russ_Anderson #70155 11/30/06 12:10 PM
Dan Offline
Wentworth is as good as any to deal with.
Russ_Anderson #70156 12/01/06 11:23 PM
try spectrum aviation, good pricing,i think 40% off of list,and good stock of nos parts. i have found other parts suppliers but most are too costly. i am always looking for a better deal also.
John_Byrdak #70157 12/02/06 01:27 AM
Thank you gents. I'll give Spectrum and Wentworth both a try. Again, thank you for your help.
Russ_Anderson #70158 12/02/06 12:46 PM
There are TWO Spectrum Aviation dealers. Use this one!
Spectrum Aviation [spectrumaviation.org]
Russ, I've been keeping an eye out for the right ASI for Dingbat, but haven't been able to verify the part numbers on those I found used on the web. Try some of the instrument rebuilders (others here may have recommendations).
