#75000 01/10/07 12:50 AM
Here is one I would hate to see go to waste [aigaviation.com]
Somebody really should pick this up and rebuild or swap her out. Man....she was purty.
What are the chances that the engine is repairable?
G
G Offline
It's amazing how much damage a high speed ground loop can cause. Back in the bad old days if you lost a Cub or a Champ and you were going fairly slow at worst you'd get a wing tip.
Geo.
George Abbott, PE
The damage reports indicate that the gear leg snapped or broke off during the ground loop (this airplane has been damaged three separate times in the past and has incomplete logs). That looks like the 140 gear, which is normally much more robust than would normally be required. Unless the gear leg merely separated from the fuselage due to a broken or missing mount bolt, there had to be something wrong with the gear leg, such as chemical embrittlement, work hardening from straightening or re-arcing, or a pre existing crack. I've seen them bent, but never broken!
Of course this airplane is rebuildable, but it should be gone over with a fine tooth comb and all previous repairs and modifications verified as complete and proper. The O-320 will need to be overhauled, and it's likely the crankshaft will need replacing. There is at least some additional damage in the right hand gearbox area. I do not think it would be an economical project for anyone but a mechanic specializing in restoration, unless the winning bid is well below normal salvage value.
Dan Offline
Any airplane with a surviving data plate is rebuildable, but this one has taken some expensive damage and, as Carl said, if feasible at all probably only an A&P could hope to come out on it. If even then. Too bad...hate to see another 150/152 parted out. <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
Ouch...
gotta agree with ya on this one, Dan.
Lotsa work and money to make that one fly again.
Ouch...
So buy it cheap and drive the STC under Mary Lou.
