| | Joined: Dec 2004 Posts: 8 Member | | Member Joined: Dec 2004 Posts: 8 | The oil filler tube on my 152 seems to be cracked where the threads are,the dip stick won't tighten down very well,it goes so far then breaks loose and spins around untill it gets snug agian.So I guess I need to find a filler tube.Does anyone have any ideas? Thanks Mike.
1980 152 II N5276M
| | | | | Joined: Apr 2004 Posts: 400 Member/250+posts | | Member/250+posts Joined: Apr 2004 Posts: 400 | The way you are descibing it, sounds like it has come loose. I don't think this will come upder preventative maint, but maybe, the tube should be safety wired so it will not come loose. if the case is the safwty wire is broke, the tube will want to unscrew, and will do the same as you described when taking the dip stick out.
Any how, pull your top cowling, maybe your bottom also, and check the tube, maybe unscrew and inspect? I suspect it is just loose and need to be secured and saftied. Good luck.
Richard McCullough N8508B
| | | | | Joined: Jan 2004 Posts: 18,962 Likes: 4 Member/15,000 posts | | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 4 | I think he's talking about the top of the tube, where the 152 dipstick screws in. Borrow another dipstick, and see if it still does it. It is common for people to overtighten these, and eventually the threads on the dipstick become worn. Your dipstick should be snug, but not "torgued" on! The 'o' ring, if in good condition, is all that is needed to secure and seal the dipstick, without over tightening it after it bottoms out.
Carl | | | | | Joined: Dec 2003 Posts: 3,062 Visit Put-In-Bay!! Member/2500+posts | | Visit Put-In-Bay!! Member/2500+posts Joined: Dec 2003 Posts: 3,062 | Carl you might have that backwards. The dip stick on my 0-320 is aluminum and the filler tube is plastic, his is more than likely the same way. If the top of his filler tube is cracked allowing the stick to "jump the threads" he is gonna have to replace the tube. Which on a Lycoming is a pretty easy job.
-Bryan U.S.C.G. licensed captain | | | | | Joined: Jan 2004 Posts: 18,962 Likes: 4 Member/15,000 posts | | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 4 | You're probably right! It's been years since I preflighted the O-235 in a 152!
Carl | | | | | Joined: Apr 2004 Posts: 400 Member/250+posts | | Member/250+posts Joined: Apr 2004 Posts: 400 | You know What Carl, I didn't think of that either  , I have had the borttom loose on a few planes that I had to tighten up.
| | | | | Joined: Dec 2004 Posts: 8 Member | | Member Joined: Dec 2004 Posts: 8 | I'll grab another dip stick and see it that one slips also,if it does,I guess I'll need a new tube.Thanks for all the advice.Now anybody know where I can find a tube.I've been looking but have yet to find one.New or used in good shape.Thanks Mike.
1980 152 II N5276M
| | | | | Joined: Dec 2003 Posts: 8,433 Likes: 3 Member/7500+posts | | Member/7500+posts Joined: Dec 2003 Posts: 8,433 Likes: 3 | I've been looking but have yet to find one.New or used in good shape.Thanks Mike. Contact a Lycoming parts distributor, I'm sure they sell them. Charles | | | | | Joined: Dec 2003 Posts: 3,062 Visit Put-In-Bay!! Member/2500+posts | | Visit Put-In-Bay!! Member/2500+posts Joined: Dec 2003 Posts: 3,062 | Or a boneyard, they would probably be a lot cheaper there.
-Bryan U.S.C.G. licensed captain | | | | | Joined: Dec 2003 Posts: 51 Member | | Member Joined: Dec 2003 Posts: 51 | To add to Chuck's referral of contacting a Lycoming distributor, here are some suggestions. Aviall - P/N 75735 Short Tube - stock at $53.68 75736 Long Tube - stock at $45.94 API - stock at $47.89 stock at $41.37 Then www.cessnaparts.com [ cessnaparts.com] shows $57.47 on the short tube but call for availability and they're showing stock available at $49.64 on the long tube. These part numbers came from my Lycoming parts manual for the L2C. Hope this helps you out.
Bob DeMunck N4735B Allen, Tx (T31) | | |
