LED Cabin Light
#657481 10/04/23 03:06 AM
B
OP Offline
B
Has anyone replaced the bulb for the panel lights behind the red cover with an LED? Looking for something brighter than whats in there now.
Thanks!
Brian
Re: LED Cabin Light
Brian Chapman #657484 10/04/23 03:53 AM
Offline
I'll be very interested in hearing from anyone who has done this.
A lot of white LED lights don't put out much red light, so it would be much better to use a red LED with a clear window. I looked a couple of times for a red LED, but haven't found anything with the right base, and I'd rather keep it to just a direct replacement if possible. There's also a chance that a replacement could cause radio noise, but I haven't gotten any to test.
Roy
[Linked Image from eznec.com]
Re: LED Cabin Light
Roy Lewallen #657528 10/05/23 04:28 AM
Offline
Few aircraft use red lights anymore. Why would you want to use them in your Cessna? Unless you want your 150 to be true to the original design, there is no reason to use red lights.
Cheers, Elliot
Re: LED Cabin Light
Brian Chapman #657533 10/05/23 04:58 AM
Offline
uh temporary night blindness from white light while flying at night.
Re: LED Cabin Light
Brian Chapman #657541 10/05/23 11:25 AM
Offline
The big Boeings I flew had one red light, and it was out on the wingtip. Everything in the cockpit was white. Some guys flew with the overhead cockpit lights on bright when we were cruising. I never did that, but I did have them on at a low level.
I tried to fly a 150 at night last week trying to get home, but I had the same issue, the light was so dim I could not read the instruments, so I found a hotel and spent the night.
My airplane has white Nulites in the instruments, a white panel floodlight, and red and white panel lights under the glareshield, but I never use the red ones.
Oh, and I put an LED loading light in the baggage compartment. That's it further back behind the speaker.
I also added two map lights, one over each door, switchable to red or white.
Re: LED Cabin Light
Brian Chapman #657542 10/05/23 11:34 AM
Offline
BTW: This has been discussed before: LED Panel Light
Re: LED Cabin Light
Michael Showah #657552 10/05/23 03:58 PM
Offline
Uh proven not to be an issue if used properly.
Re: LED Cabin Light
Brian Chapman #657556 10/05/23 05:10 PM
Offline
https://www.cfinotebook.net/notebook/aeromedical-and-human-factors/vision
https://en.wikipedia.org/wiki/Flash_blindness
https://www.planeandpilotmag.com/article/avoiding-night-blindness-while-flying/#:~:text=The%20pigment%20in%20the%20rod%20cells%20is%20called,blindness%E2%80%94the%20inability%20to%20see%20things%20in%20low%20light.
just the known facts you can fool yourself but not mother nature.
Where is it proven data?.
Please provide link to referred reference, it would be interesting.
Re: LED Cabin Light
Michael Showah #657563 10/05/23 07:19 PM
Offline
There has been debate for years that blue or green light is better than red for illumnation while preserving night vision.
One such discussion. [cruisersforum.com]
I've always used red myself and never had an issue.
RE: the dim light in a standard 150 overhead instrument panel light - that is why I always used to wear one of these [mypilotstore.com] when flying at night. It's a shame that didn't come up in conversation at your departure airport prior to your pre-flight Mark, someone might have sent one of these along with you...
States I landed in N63420 while she was mine:
KDCY
"And once you have tasted flight, you will walk the earth with your eyes turned skyward, for there you have been, and there you would return." - John H. Secondari, American TV Writer, 1965
Re: LED Cabin Light
Brian Chapman #657572 10/05/23 10:42 PM
Offline
I use this LED with the stock red lens for my overhead instrument lighting.
Saves power and is dimmable with the stock rheostat.
At full power is too bright (red) at night but you can see your instruments even when dialed down. (dimmer is better).
https://store.marinebeam.com/12-led-bayonet-reader-bulb-replacement-ba-15-12x/
instruments are backlit Dimmable Led's.
UMA ELECTROLUMINESCENT INSTRUMENT LIGHT BEZELS
https://umainstruments.com/
digital panels all dimmable also.
EI, JPI, Dynon, Ipad.
