Ex NASA DE HAVILLAND C8 | Joined: Jun 2011 Posts: 18,013 Likes: 1757 Member/15,000 posts | OP Member/15,000 posts Joined: Jun 2011 Posts: 18,013 Likes: 1757 | 1974 DE HAVILLAND C8 - Quiet Short Takeoff And Landing Test Jet Full Details: https://www.gsaauctions.gov/auctions/preview/265803 Graeme J W Smith | | | Re: Ex NASA DE HAVILLAND C8 | Joined: Jun 2004 Posts: 35,101 Likes: 426 DA POOBS Member with 30,000+ posts!! | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 35,101 Likes: 426 | [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | | Re: Ex NASA DE HAVILLAND C8 | Joined: Mar 2004 Posts: 11,364 Likes: 263 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 11,364 Likes: 263 | An interesting piece of aviation history. The aircraft has not been maintained to FAA standards. (Ya think?!) The true condition of the aircraft is unknown. Bidders are strongly cautioned to inspect the aircraft prior to bidding.
The aircraft is a highly modified deHavilland C-8A Buffalo consisting of a new swept, supercritical wing and 4 YE-102 geared, high-bypass-ratio turbofan engines mounted in an “over the wing” installation. Upper surface blowing is used to generate high-lift coefficients to provide low approach speeds and steep approach path angles.
David Rowland 7CO0 | | | Re: Ex NASA DE HAVILLAND C8 | Joined: Oct 2006 Posts: 10,981 Likes: 722 Member/10,000+ posts! | Member/10,000+ posts! Joined: Oct 2006 Posts: 10,981 Likes: 722 | That is so utterly cool and amazing. There were times in aviation history when there were funds available to do some very cool research.
Can you imagine dealing with a fistful of throttles, coming down final at maybe 1.15 Vso, trying to land that sucker short? | | |
