| Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | I have a set of flat spring landing gear for sale from a 1964 Cessna 150D. $150 for the set, but you pay for shipping and must take both.
| | | | Joined: Dec 2006 Posts: 499 Likes: 1 Member/250+posts | Member/250+posts Joined: Dec 2006 Posts: 499 Likes: 1 | I'll take them and I'll pay shipping if they have the right bolt pattern for the axles. Do they have the 3/8" bolt holes for the lower 2 holes and the 5/16" bolt holes for the upper holes?
If all of the holes are the same diameter then I can't use them.
Mike Sibley
907-398-6778
| | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | The Newfangs have first dibs. I've got a pile of gear legs and will look through for another set but think the rest are for bigger aircraft.
| | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | I came up with a second set of gear legs I'd forgotten about (insert "might be a redneck if" joke here). Same price.
| | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | Okay, I found one gear leg for you. It's the right side with the correct bolt pattern for you. How about $80 for the leg or $100 for the leg with the matching axle, shims, and brake caliper mount?
My phone is 520-370-2498
| | | | Joined: Jan 2013 Posts: 9 Member | Member Joined: Jan 2013 Posts: 9 | Kendel
I'm looking for a set of flat springs for my 150H part no's 0441186-1 & 0441186-2
Have a few inquiries out to some salvage companies but if you come across anything I would appreciate your help.
I'm down under in good old Kiwi land, New Zealand and not much in the way of spares here I'm afraid.
Cheers | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | I have part numbers 0441163-9 and 0441163-10. I don't know if those supersede or are equivalent numbers for you.
| | | | Joined: Jan 2013 Posts: 9 Member | Member Joined: Jan 2013 Posts: 9 | Thanks but they were for the earlier models from 1959-1965 up to "E" models
I need the next series from 1966-1969 models "F - J " models.
Still looking
Cheers | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | I believe Mike Sibley (a member here) collects those. He has them re-arched and re-tempered for tailwheel conversions, but might be able to put you onto a stock set.
| | | | Joined: Jan 2013 Posts: 9 Member | Member Joined: Jan 2013 Posts: 9 | Do you have his details or are yo able to find out for me? That would be great. Cheers | | |
