Here's a picture of Mike's landing gear in action with him at the controls. You can see the reason for the mod. The reason I think he uses the same model numbers is that he runs the beefy steel axle to support those monstrous tires and it's only on the later bolt pattern... I think.
Mike
I'm looking for a set of flat springs for my 150H part no's 0441186-1 & 0441186-2
Have a few inquiries out to some salvage companies but if you come across anything I would appreciate your help.
I'm down under in good old Kiwi land, New Zealand and not much in the way of spares here I'm afraid.
Kedel McCarley suggested contacting you.
Unfortunately grounded until they are replaced http://www.cessna150152.com/forum/images/icons/default/frown.gif
Cheers
Do you have a set of the tube gear legs for a C150M?
Thanks!
