| | Joined: Jun 2011 Posts: 1,619 Member/1500+posts | | Member/1500+posts Joined: Jun 2011 Posts: 1,619 | The last couple times I went flying there was oil under the calipers on the floor. This was an issue 3 years ago at annual. We removed the calipers and took out the pistons to clean them up. There was a lot of corrosion inside the caliper where the piston goes. We cleaned it up really good with scotchbrite and put a new seal kit in it hoping for a good outcome. Well I got 3 years out of that but don't think it will work again. So now I'm on the hunt for 2 calipers in great shape.
The IPC says this should be part # 061-01900
Bruce Bennett Visited | | | | | Joined: Feb 2004 Posts: 1,998 Likes: 532 Member/1500+posts | | Member/1500+posts Joined: Feb 2004 Posts: 1,998 Likes: 532 | Bruce I gave up looking for decent used calipers when I checked the new price of a bare cylinder. I could transfer all the other parts, usually in good shape, to the new cylinder and have a great unit with out having to send a couple of bad caliper assys back for exchange. You might look into that solution. Alan | | | | | Joined: Jun 2011 Posts: 1,619 Member/1500+posts | | Member/1500+posts Joined: Jun 2011 Posts: 1,619 | Just got a quote in from the Cessna parts dealer in Ontario.
$1100.00 for 2 brake cylinders and 2 pistons. Ouch!
Bruce Bennett Visited | | | | | Joined: Feb 2004 Posts: 1,998 Likes: 532 Member/1500+posts | | Member/1500+posts Joined: Feb 2004 Posts: 1,998 Likes: 532 | Bruce Aircraft Spruce shows the bare cylinders for $257 each. Alan | | | | | Joined: Jun 2011 Posts: 1,619 Member/1500+posts | | Member/1500+posts Joined: Jun 2011 Posts: 1,619 | Alan,
I can't seem to locate the cylinder on ACS Canada. Do you have a ACS part#?
Never mind. Found them. $359.00 CDN
I don't remember if the pistons are chromed or not. Do you think I will need new pistons too?
And what about the o-ring. I did a search and can't find the Cessna number anywhere.
Bruce Bennett Visited | | | | | Joined: Feb 2004 Posts: 1,998 Likes: 532 Member/1500+posts | | Member/1500+posts Joined: Feb 2004 Posts: 1,998 Likes: 532 | Bruce Pistons are aluminum and generally don't corrode like the cylinders do. 101-05200 is the Cleveland p/n for the o-ring. Alan | | | | | Joined: Jun 2011 Posts: 20,316 Likes: 2962 Member/20,000 posts | | Member/20,000 posts Joined: Jun 2011 Posts: 20,316 Likes: 2962 | Cleveland are now owned by PArker Hannafin. They have a search tool for your nearest distributor if you want to do a little shopping: Click Here [ parker.com] | | | | | Joined: Feb 2008 Posts: 457 Member/250+posts | | Member/250+posts Joined: Feb 2008 Posts: 457 | Hi Bruce. Did you want Cleveland or McAuley ? There is a dismantler (wrecker) out this way, I could check for you. Tom
1973 150
| | | | | Joined: Jun 2011 Posts: 1,619 Member/1500+posts | | Member/1500+posts Joined: Jun 2011 Posts: 1,619 | Thanks Tom but I think I will go new when I get to them.
