Re: Floor Brackets For child seat
Jim Hillabrand #604744 07/09/20 04:38 PM
OP Offline
It sure is....!
N2968S 1967 Cessna 150
Robert Voyles #607533 08/23/20 04:30 AM
Offline
Robert,
We're you successful in making the brackets and installing the seat? I have a seat but need brackets as well.
Freddy
Freddy Williams, Riyadh, Saudi Arabia
C150M N66197 (Pickled at KSMS)
Robert Voyles #617004 02/02/21 10:03 PM
C
Offline
C
wow awesome. Thanks for doing this!
Robert Voyles #617006 02/02/21 11:23 PM
Offline
Material is most likely 2024 T3 like all Cessna Al parts.
Can be ordered from online metals.
Do you have a thickness??
This has to be bent on a radius or it will crack.
Best way to do the bend is bend a piece of .63 (5051) on the bending brake. (this makes a radius finger to bend the 2024 without cracking it)
Leave it on the brake and then make the bend of 90 degrees.
Make your flat pattern a little longer to accommodate the bend.
It will make a nice strong bend.
You cannot use a standard brake without the bent .63 .
Robert Voyles #627450 08/15/21 02:15 AM
Offline
Very cool. Any update to getting these parts made up? What thickness material did you go with?
1 member likes this: Freddy Williams
